menu ring
Hi:
I am using a control called "Menu Ring" and I want after selecting an item it reinitializes to default vaule.
How I can do it?
(2,701 Views)
Right click on the ring, and select "Create - Property Node." Then on the node, change it to "Write" and change the property to "Value."
Now, wire the default value into it, and set it to execute after you have used the value that the user sets into the manu ring.
Don't know if it's "clean", but it should work. 🙂
Les Hammer
(2,701 Views)
