memory error viewing embedded vi
After installing LabView 6.1 I was trying to
use the ability to control the VIs over the
web. So I embedded a VI in a page and called
it up on Internet Explorer. Everything seemed
fine, but I could not start the VI over the web
page, so I started the acutal VI (which I had
on screen). I got a memory error and LabView
crashed. I have attached a bitmap of the error
I recived
(2,643 Views)
To gain control of the VI in the web browser you must right mouse click on the front panel and select "Request control of VI". Once control is granted you can run the VI by clicking the run button.
Do you have the same problem if you run a small, simple VI?
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,643 Views)
