memory deallocation of globals
Dear all,
I am using tab control to switch between different front panels of diss VIs.
In one VI, i am using global variable for data allocation.
i want to know when i close this Vi, and go to front panel of other VI, will the memory allocated by the Global(in first VI) be deallocated or will it still be there in memory ?
Ritesh
(2,613 Views)
It should still be take up the same amount of memory until you close the program OR assign the global variable to something else (like an empty array).
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(2,580 Views)
I don't have LabVIEW in front of me, but there is a download here that may be of interest to you.
http://zone.ni.com/devzone/cda/epd/p/id/4545
From a developer's perspective, is a Global not basically treated as a subVI with no block diagram?  So, wouldn't LV release its memory space when its last caller closes?  I actually went looking for a "Show All VIs" VI for you, and stumbled upon the one above.  Hope it helps...
Message Edited by LabBEAN on 02-14-2009 11:01 PM
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
(2,567 Views)
