measuring signal to noise ratio using USRP and labview
I Have a problem that I Can't  measure the signal to noise ratio  of a signal using USRP 2932 and labview,so I will be grateful for any help from anyone.
thanks alot
(3,089 Views)
You'd have much better luck posting in the USRP board: https://forums.ni.com/t5/USRP-Software-Radio/bd-p/500. You'll find more user working on the same kind of applications there. There are also already several topics on SNR measurements:
http://forums.ni.com/t5/LabVIEW/Signal-to-Noise-Ratio-SNR-measurement/td-p/99326
http://forums.ni.com/t5/LabVIEW/how-to-calculate-signal-to-noise-ratio-from-the-graph/td-p/813558
Cason
NI Applications Engineer
Cassandra Longley
Senior Technical Support Engineer - FlexRIO, High Speed Serial and VRTS
(2,968 Views)
thank you very much  Cason_Point, you are helpful ,I relay benefit of your solution ,it help me solving my problem ,I Hope you will help me if I face another problem if you don't opposes:
(2,935 Views)
