10-08-2008 10:52 PM
I have LabVIEW 8.5.1 and NI DAQmx 8.3.1 running on Windows XP.
I don't seem to have any vi's in my "Measurement I/O" palette except for Max configuration and VI Logger.
I don't have DAQ assistant, DAQmx write, DAQmx read, or any of the Legacy read or write functions.
Any help would be appreciated...thanks.
10-09-2008 03:09 AM
Hi UTexEE,
If DAQmx is properly installed, it should have created a .mnu - file which you can link to your palette. On my PC (Win Vista) it is located at "C:\Program Files\National Instruments\LabVIEW 8.5\menus\Categories\Measurement\daqmx.mnu". To link it to your palette you have to click at Tools>>Advanced>>Edit Palette Set.
Hope this helps,
greets, Dave
10-09-2008 06:49 AM
Thanks for the info...
I was finally able to get the NI DAQmx palette in the Measurement I/O but I still have so many VI's that have a question mark. The one in particular that I'd like to use is the DAQ Assistant and I can't seem to get that. I do a search in the directory and I can't seem to find a file called "DAQmx Assistant Block.vi" which is the path to the palette file according to the Edit Controls and Functions Palette Set.
Any ideas? Thanks again.
10-09-2008 07:11 AM - edited 10-09-2008 07:13 AM
On my PC the path is "C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\express\DAQmx\DAQAssistantBlock.llb\DAQmx Assistant Block.vi". Did you see it's inside an LLB?
But over all, I think, l your DAQmx- installation is corrupt and needs to be fixed in a whole. Perhaps you can do it the easy way by repairing it via the National Instruments - Software panel or you have to completely remove and then reinstall the DAQmx Driver. You can access the NI- Software Panel via System Control>>Remove Software>>National Instruments Software. This opens the Panel shown below.
Hope this helps,
Dave
