measurement and control via Producer/Consumer
Hello Again,
I know i should throw this up to te Real.Time Forum, but maybe the Answer is so quite simple that there is no use for an new Thread.
I try to apply the System on an cRio9074.
The Target should only Read and write, Signals to an actuator.
The Host should control the process & generate Signals, just as seen in the Example Above.
Now my problem is, that as I see, i cannot use DAQmx blocks with the cRio components.
Do I now have to use these FPGA Stuff, or can i just put my AI-Variable into the Target and let it Read with an self-created Global-Variable??
And can This Variable be to the Host, in real-time porcessed ??
Maybe my Attachement will Help to understand.
Thank you
Message 11 of 11
(352 Views)
