measurement analysis using TDS3000
Hello
HI. i am using TDS3000 downloaded from NI website
Actually graph that is produced from labview measurement as i attached in the attachment. ie the labeled came out as
Vpeak= ___V
90% OF the graph in term of seconds
10% of the graph in term of seconds
As i am doing impulse testing i need those parameters for analysis
Here also i attached my modified programming
(3,484 Views)
I don't understand what your problem is.  Are you just trying to make the measurements and don't know how to?
(3,456 Views)
hi thanks for reply.
I have an xy-graph and I would like to insert programmatically some text label connected to certain x-y coordinates of the plot itself and display it at the front panel
(3,449 Views)
Well, you have the array of data.  So just use the Array Max & Min to get the peak voltage.  From there, get your 10% and 90% voltage levels and use Threshold 1D Array to find the index of those points.  You may need to use Interpolate 1D Array with the resulting indecies and the time array in order to get your time of those points.
(3,443 Views)
From the peak value, is there any method for it to plot itself 10% and 90% voltage levels crossrulz?
(3,434 Views)
Not itself.  But you can easily make the lines and add them to the graph plot.
(3,426 Views)
Hello I have 1 more problem related to this topic, which is i planning to do an array for my programming, but the wire cant connect each other. Here i attached the picture of my problem. Hope someone can help me
(3,399 Views)
