measure pixels distance
Hi everyone!
I would like to measure the radius of each pixels by reading BMP file. BMP dimensions is 50x50 pixels and each pixel size is 0.032 milimeters.
This is what I've done so far. I was able to get only grey level of pixels in diagonal lines but I would like to get each pixel's distance(milimeters) from center point of the circle.
Can anyone show me a way on how to do it?
Thanks 🙂
 (I attached jpg file because i couldn't upload bmp file)
(3,828 Views)
Hi rainy01!
altenbach posted this very neat vi
The linked vi calculates an centered euclidian distance transform  in px of a given input image.
All you have to do is to scale it up by multiplication with your mm/px factor (0,032)
The euclidian distance is calculated very efficient in altenbachs approach via complex numbers.
You also could try a more explicit approach without complex numbers by using directly the i of the FOR loop and arithmetic functions.
Alex
(3,774 Views)
I understand. Thanks! Helped me a lot! 🙂
(3,742 Views)
