measure phase difference between 2 signals
I am very new to labview. i m trying to use labview to measure phase between 2 signals from encoder. I also want to measure the state of 2 quadrature square signals. anyone has any idea how to do it?
(2,742 Views)
Hi "rvn10",
Quadrature encoders do by nature have a phase difference of 90 degrees between channel A and B. This phase difference is required to know in which direction the shaft is rotating when a transition from one of the channels is received. Please see these two links for some useful information:
Encoders
Quadrature Encoder / Position Measurement
If your goal is to measure the angular position using the two quadrature square signals, then your task is quite simple if you use one of our Counter/Timer cards. Check for example the shipping example called "Measure Angular Position.vi".
If you want to read more about our most affordable Counter/Timer product, then check this link:
NI PCI-6601
Please let us know if you are using different hardware to acquire the signals.
- Philip Courtois, Thinkbot Solutions
Thinkbot Solutions
(2,710 Views)
