measure angular position using rotary incremental encoder with Arduino
Hello!
I'm trying to read pulses from the rotary encoder by using this code but it is showing random garbage values. how can I read values from the encoder by using phases A and B?
Is this necessary to have encoder vi to reading the values from it?
If yes, kindly provide it if you have any. Thanks!
Message 1 of 9
(3,810 Views)
What you posted seems to be a code to read a potentiometer, not an encoder with AB(Z?) signals, so that might be your problem.
EDIT:
The code you posted is titled "ANALOG pin read example" and uses what seems to be potentiometer hooked up to +5V, GND and a signal line, which is the analog voltage you are (supposed to be) trying to read.
encoder with AB signals would most likely be digital and and would have 2 signal lines (3 if it includes the Z signal) and power lines.
Reading that kind of encoder with a single line analog read would equally result in reading garbage data.
Message 2 of 9
(3,791 Views)
Thank you for your info!
Actually, I am trying to use a rotary incremental encoder using LabVIEW & Arduino. can you kindly guide me on how can I control the encoder?
Message 3 of 9
(3,764 Views)
You have to use the interrupt pins which they are pin 2 and 3 in Arduino uno. You can use the attached example.
GOOD LUCK
Abdallah Farmalawi
Message 4 of 9
(3,721 Views)
Hello!
Thank you for the code.
I did all the things mentioned in the file. I uploaded LIFA on the Arduino compiler. I used pins 2 & 3. During running code on LabVIEW, the encoder was not showing any result on LabVIEW. the count is not increasing or decreasing when I change the position of the encoder.
Kindly tell me how can I resolve this issue. Thank you
Message 5 of 9
(3,698 Views)
Hello!
I'm trying to read values from the encoder using this code
I used pins 2 & 3. During running code on LabVIEW, the encoder was not showing any result on LabVIEW. the count is not increasing or decreasing when I rotate the knob of the encoder.
Message 6 of 9
(3,673 Views)
Why aren't you using LINX?  LIFA is obsolete and was replaced by LINX.
Message 7 of 9
(3,669 Views)
Hi!
can you guide me on how I this LIFA based code into LINX? because it is very difficult to find an encoder block in LINX. Thanks
Message 8 of 9
(3,644 Views)
If the encoder pulses are coming quickly then an arduino alone using interrupts on A and B wont keep.
From my experience, you will need to find a suitable quadrature counter chip and interface to it from the arduino using something like SPI or I2C, to periodically poll for the latest count.
Some chips I have seen have the ability to trigger an interrupt line when a certain count is reached. What is the best approach will depend on the application.
0xDEAD
Message 9 of 9
(3,630 Views)
