mcp2210
I am not able to connect the Microchip MCP2210 to connect to Labview. I used the driver wizard to creat a driver based upon the VID and PID but when I install it shows on device manager as shown on attached but says can not start. Any help would be appreciated.
(4,880 Views)
That is simply wrong.
Install the Microchip driver.
Then apparently you will need to learn how to call their DLL.  Google it.
All this information is in the other thread where you also posted. NOTHING has changed.
(4,876 Views)
Tried that before and Labview does not like MCP2210 dll.
(4,867 Views)
That's not a very technical description of any problems you might be having with a call library function node.
(4,858 Views)
Then try a programming language that you *do* know and does "like" the DLL.
(4,839 Views)
