A couple questions, when you writing to the file the second time didn't work, what exactly happened? error message? original contents over written?
Second, how long is there between the first write to the file and the second write? Some things to check is whether the first write is closing the file when it finished, and did you by chance open the target file with some other program than LV between writing to it the first time and writing to it the second time? That will sometimes change the format of a file without you realizing it.
What is the format of the data in the file?
Mike...
