maximum value for 2D array
I'm using 7.1.  Does anyone have a subvi made up already for getting the maximum value from a 2-D array?
(6,447 Views)
the vi in the Array pallete named Max and Min is a polymorphic vi that you can wire in a 2 d array that ill find the max and min
Kenny
Kenny
(6,421 Views)
Here is something I wrote in 7.1
Brian
Brian
(6,420 Views)
Kenny is right. just wire the 2D array to array min&max. No need to jump through loops (sic) 😉
The index output will be an array where the elements correspond to the indices of the Max element in all dimensions.
(6,416 Views)
I guess I must like the exercise.
Brian
(6,406 Views)
