maximum number in a Single precision floating number
Hi everyone,
I would like to know which is the maximum positive and negative number I can write in a SGL numeric control. I read the Numeric data types table  in the LabVIEW help and I am not sure if the numbers in the column "approximate range on disk" are the maximun and minimum ones because I wrote in a DBL numeric control the number 6216825840 (which is less than the maximum on the table 3.40e+38) and I displayed it in a SGL numeric indicator, and the number changed.
The problem is that I am storing some data in the numeric format and  I choose the SGL format because it uses less space in the disk, however I have the number 6216825840 which changes if it is storaged in this format. I know that I should change to DBL, but I am doing an array with all my data and if I change one by BDL the other ones change to DBL and will use more space in the disk when I store them.
I attach a picture of this problem.
Thanks in advance.
JC
(6,393 Views)
JCNT wrote:
I would like to know which is the maximum positive and negative number I can write in a SGL numeric control. ....
This is a precision problem/limitation, not a max/min problem.
SGL is limited to ~7 digits precision.
With DBL, you have ~15 digits precision.
Fading out. " ... J. Arthur Rank on gong."
(6,363 Views)
Hi Donald,
Thanks for reply,
You mean that I could  just write until the number 9999999?
JC
(6,361 Views)
No.  You are not limited to 7 digit numbers ... as shown by the 10 digit SGL 6216825856 in your JPG.
But a SGL cannot give you precision beyond the 7th digit: 6216825xxx
Message Edited by Donald on 06-15-2007 03:40 PM
(6,350 Views)
And since the numbers are stored in binary, the resolution in decimal digits is just approximate.
SGL has a 23 bit mantissa (http://en.wikipedia.org/wiki/Single_precision), so you cannot do better than 2^24 for integers.
Your number does not even fit into a U32, which has all 32 bits reserved for the integer part. 😮
(DBL has a 52 bit mantissa.)
(6,335 Views)
In particular, you can create a simple test program that shows you that the highest good integer is 16777216 for SGL, because 16777216+1=16777216.
For deep reasons, this is the same as 2^24 as mentioned above. 🙂
Here's a quick code that stops the loop once i = i+1, then displays i (the fist integer that fails the test, thus is the largest good integer for SGL. 🙂
Message Edited by altenbach on 06-15-2007 01:33 PM
(6,332 Views)
Hi Donald and altenbach,
Thanks so much both of you for your help, now I understand what you mean. So, I don't have any choice and I must store my data in DBL format.
Thanks again and I'm really glad that there are people like you who help people with these problems.
Regards from Ecuador!
JC
(6,310 Views)
