matrix variable
how can i use variables inside the matrix , to control them from the front panel, plz help me im new in LabVIEW
Message 1 of 8
(4,801 Views)
Your matrix is already a control and you can fully operate it at run time.
Message 2 of 8
(4,797 Views)
but i need to make some elements as separated variables and others as constants for example:
    1  0  tx
    0  1  ty
    0  0  1
Message 3 of 8
(4,790 Views)
    1  0  tx
    0  1  ty
    0  0  1
Message 4 of 8
(4,790 Views)
You are talking about controls, not "variables". Just create an array control with two elements and replace the desired matrix elements with its value. Is this to be operated from the front panel ot to be used in plain code?
Can you explain in more details what you are trying to do?
Message 5 of 8
(4,771 Views)
if i need to use another variables with cosine and sine (replaced to Tx and Ty ) , the angle must be controlled and the cos or sin is calculated after that this value insertes the matrix
1  0  cos th
0  1  sin th
0  0     1
Message 6 of 8
(4,756 Views)
Do you want the contents of this matrix to be editable on the front panel, or do you just need it to be available in memory? If you just need it available in memory you can define your matrix using a matrix constant then simply use the set matrix elements function to manipulate the values.
Something similar could be done with a control and property nodes. If you just want to display it, an indicator should be sufficient.
Message 7 of 8
(4,717 Views)
Maybe some basic terminology would be in order.
In LabVIEW, "constants" are just initial values that don't have a corresponding front panel element: they are fully editable programatically.
You also need to forget the concept of symbolic variables. Just treat every element as a distinct value. If you need to manipulate the data within it based on other data, just calculate the value you want that element to be and place that value in there using an appropriate function.
It's a very different conceptual process than that used in most text-based mathematical environments and can take some getting used to. Maybe if you could give us a better idea of what your big picture is, or even post some pseudo-code we could be of a little more help.
Message 8 of 8
(4,714 Views)
