matlab with vision
hey i am bak with some more quirires and qusetions =((
i am trying to import the matlab codes for the image to be converted to rgb,binary,hsl and grey..bt when ever i innput an image the output is a pure blak image.kindly help me out.i am posting ma vi too.
Message 1 of 9
(4,471 Views)
Could be a problem in passing the datatypes and how this "other software" is handling that.
Don't you have the NI Vision Development System to do this?
Christian
Message 2 of 9
(4,454 Views)
i am importing the matlab codes..no i am not using the vision dev systems.basically loading an image from the memory and then working on it by using matlab..kindly tell me the way out,plz give me a block diagram too.
thnx
rep soon.
Message 3 of 9
(4,442 Views)
In the VI you attached, the array is not wired from the script node to the "IMAQ ArrayToColorImage" VI.  What happens when the 'H' array is wired?
Chris M
Message 4 of 9
(4,433 Views)
hey,i have modified the program and getting the output for the conversion in to grey,rgb and hue image but when i try the same vi to get the output picture of the binary image it gives an error that unable to pass the the variable =(((..i am attachin the vi too.i have given the input image of a car and then applied the image proessing techniques..plzz tell me some way out...also u can see in the picture attached below that the output comes out to be in yellow color.i used the flattend/unflattened pic tp pix map vi too but still it givs a black screen...kndly tell me a way out.
Message 5 of 9
(4,416 Views)
oops forgot to attach the vi.here it goes.will b very thankful if u help me.
Message 6 of 9
(4,413 Views)
the result is not being posted...=(( kindly run it plz.input is attached.
Message 7 of 9
(4,412 Views)
 hey,plzzz reply
need serious help
can u tell me a way out so that:
1)i can detect all the horiaontal edges in the image without giving the ROI manually???
2) and then out of all those horizonatl edges how can i extract the first and the second widest horizontal line(max and the 2nd max horizontal edge)..
3)also after extracting those max edges how to calculate their co-ordinates for the ceopping of that image..
plzz do reply..
thnx
Message 8 of 9
(4,351 Views)
I can't help you do this in a text based language but we do have vision software that can do what you need.  We also have the Machine Vision forum.
Text based programming isn't a strength of mine, sorry.
Justin Parker
Product Support Engineer
Message 9 of 9
(4,329 Views)
