07-11-2007 03:52 AM
07-11-2007 03:52 AM
07-12-2007 11:49 AM
Roiht,
To be clear, Matlab and MathScript are not the same. MathScript understands the syntax of .m files, the same way multiple IDEs can understand .c files. However, this does not mean that all the functions of Matlab are the same in MathScript. There is a list of all of the LabVIEW MathScript functions here:
LabVIEW MathScript Function List
You will want to check and see if the functions you are using are available in MathScript. If not, there may be a similar function that you can use. I would also suggest taking a look at the Starting Points and Resources for Learning LabVIEW MathScript document. It has a lot of good information about using MathScript in LabVIEW. I hope this helps.
07-12-2007 12:22 PM
roiht,
Since it looks like you are only using a MATLAB Script Node, I'll assume that you aren't using MathScript as mentioned in Brian's post, but please correct me if I'm wrong. When you run this VI does it produce any error messages, or does it just run without the script node producing any plots? If you are getting an error, then there may be a problem with the path that would prevent the dispnew function from being called. This can be addressed by using addpath in your script node. It also looks like the values of "f1" and "M" aren't being set anywhere here.
I'm not sure whether you have been able to run any other MATLAB Script Nodes. This would help us figure out if there is a problem with this specific script or with the functionality of the script node in general. Try running a very simple MATLAB Script Node from a new VI to see if it works properly.
Also, which versions of LabVIEW and MATLAB are you using?
Chris M
LabVIEW R&D
