mathscript crashing in 2009
Three of my PCs and a laptop freeze when I open any vi containing a mathscript node.
It's often ok if I open a new vi and create a mathscript node wioth nothing else in it, before I open one of my bigger programs. What can I do?! They're all running winxp sp2
Thanks.
(2,463 Views)
Hi gdwwbb01
Does this behaviour happen with the same VIs that you are attempting to open on different machines or is it with any VI that has a math script node in it?
Has this problem just started or have you always had it?
Do you get any errors?
Regards
Robert
National Instruments UK & Ireland
(2,444 Views)
Hi Robert,
The problem has always happened, with any PC running any vi containing a mathscript node. The only common feature is the installation of LV 2009, which I haven't had any other problems with.
Graham
(2,442 Views)
