matching colors to an array of saved templates
hello there, i am currently doing a project involving vehicle licence plate recognition in labview using ni vision. a part of this project requires use of a color matching algorithm. till now, i have been experimenting with the vision assistant to help me with a good color matching algorithm to use. loading and saving templates were done with ease. however, the problem here is , i need to evaluate all templates to recognise the color of the vehicle. vision assistant contrainted me to use a single template for an image. any ideas of further pursuing this topic is greatly appreciated. thank you
(2,943 Views)
Not trying to give you the brush or anything like that, but there is a Machine Vision board that you should probably post this question to. You're likely to get a better/quicker answer from there.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,933 Views)
A single color match step in Vision Assistant will only allow a single template, but you should be able to use several color matching steps to search for a variety of templates.  Try this and let me know if you have any additional questions.
Scott R.
Scott Romine
Course Development Engineer
(2,912 Views)
