match regular expression and add to array
hello. Im having some issues with this.
I have a very long multi line string with a lot of numbers in it. The string is from a HTML so contains a lot of junk as well.
I want to match the expression <td class="s0" dir="ltr">[0-9].[0-9]</td>
[0-9].[0-9] being either a 2 digit or 3 digit number with 2 decimal places (100.11 or 99.88) and then take these numbers and add them to an array.
i tried matching the expression <td class="s0" dir="ltr">[0-9].[0-9]</td> but tht just returns <td class="s0" dir="ltr"> </td> from the whole match node.
am i using this right and if so why is it not pulling up the numbers.
(4,945 Views)
Hi Ace,
an idea without using RegEx:
(4,939 Views)
Scan from String and Format into String are two of my favorite String functions.  Expanding slightly on Gerd's example,
(4,909 Views)
Hi Bob,
when parsing HTML files "manually" it seems less error prone (IMHO) to search for some "markers" first and then use ScanFromString on the data just following those markers - that's the reason to use MatchPattern first, followed by ScanFromString…
(4,903 Views)
Can you provide us with a typical multi line string and the expected match?
Ben64
note: in your regex the dot will match any character not just the decimal point, to litterally match the decimal point you need to preced it with the escape character \.
(4,895 Views)
Try this
Ben64
(4,887 Views)
I posted a snippet that uses Match Pattern to find the stuff between HTML tags here - http://forums.ni.com/t5/BreakPoint/Regular-Expressions-Board/m-p/1193689#M13534
The regex was <(\w*)>(.*)</\1>
Right away, I see that your regex looks for exactly one digit after the >, then one of anything then exactly one digit before the next <.  You need to specify repeating character classes and escape the decimal point.
Jim
(4,868 Views)
