match pattern numbers and strings
I am trying to use match pattern to read numbers and strings from a file. I can't seem to figure out how to allow the function to read the strings. For example, if the file contains the following:
1.1 2.1 3.1 Cat DOG
I would think that [.]?[0-9]+[.]?[0-9]*[Cat][DOG] would do the trick. Any pointers?
Micah
(5,227 Views)
Match Pattern isn't as powerful as Match Regular Expression, and some of what you're trying to do requires that power.
I changed your regexp a little by escaping the decimal points, grouping/repeating the number search and making literals out of "Cat DOG".  We'd need a better description, or a more representative sample, of your expected data to do more.
([\.]?[0-9]+[\.]?[0-9]* )*[\w\s]*
Jim
(5,204 Views)
(5,202 Views)
When I use this syntax for the regular expression input, my code only picks out the string and does not read the numbes. To expand a bit on my projet, the file I am reading in has 12 columns but I only care about the 1st, 9th, and 11th columns. The problem I am having is columns 10 and 12 are the strings (indicating fault degredation modes in a test bed). I simply want my code to read in all the columns and then I'll process the data that I need.
Micah
(5,175 Views)
@apok wrote:
This is not a solution, %s will match any string not only Cat and DOG and if the input string do not match the format string it will generate an error.
Ben64
(5,174 Views)
@Micah59 wrote:
[...] the file I am reading in has 12 columns but I only care about the 1st, 9th, and 11th columns. The problem I am having is columns 10 and 12 are the strings (indicating fault degredation modes in a test bed). I simply want my code to read in all the columns and then I'll process the data that I need.
Micah
If the data is always deliminated by spaces, you can use Spreadsheet String to Array:
If you need to do anything with the fault strings, you can replace the Double constant (in the array constant) with a String and convert whichever numbers you need from the resulting array of Strings.
Jim
(5,151 Views)
