mass flow controller
hello,
does anyone have or know of a vi that can be used to read and display mass flow of a gas?
i have a mass flow controller(MFC) and it reads the gas flowing thru a pipe (or a tube, forexample). i want to be able to take the readings or signals from the MFC and display it on the front panel.
does anyone have something(VI) of the sought that i can maybe modify to do what i'm trying to do?
thanks
-r
(2,820 Views)
A lot of MFC's have an analog out denoting the "is" value of the mass flow.
Connecting this analog out (from the MFC) to an analog in of a DAQ card will allow you to record the values.
This is an easy thing to do (If your MFC has a simple analog out), so I'm not sure if you'll find ready-made functions for it.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(2,820 Views)
You might also want to check the following link that points to another similar Discussion Forums posting.
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000006E8D0000&ECategory=LabVIEW.LabVIEW+General
Ankita A.
(2,820 Views)
