mapwindow in labview
is there anyone use  mapwinGIS(activeX)  in  labview?
(3,307 Views)
Hello Never_More,
My name is Larry and I am an Application Engineer at NIUK, I apologise for the delay the response however I hope this information helps.
Do I understand correctly that you are trying to implement an ActiveX in LabVIEW (in this case a GIS program)? If this is the case I have found a good tutorial which describes a step by step process of implementing ActiveX in LabVIEW, and can be found here:
Tutorial
Further information on implementing ActiveX can be found here:
NI ActiveX
I hope this resource helps with your application. If you have further questions do not hesitate to reply on the forums.
Laurence Colvin
National Instruments UK
Larry Colvin
Associate Principal Engineer
Dyson Technology Ltd.
(3,105 Views)
