map with labview
@Cagri1 wrote:
I want to take GPS data with Adafruit GPS module, process it with Raspberry Pi Pico and transfer it to the LabView interface.
IMO:
If it is a personal project:
    if you know how to code but cant figure this out, show us your existing code.
    if you are learning how to code:
                    If you must use the RPi, don't run Labview on it
                    If you want to learn Labview, don't use a RPi to run Labview
If this is a commercial project I would run away.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 11 of 20
(845 Views)
It can also be done via Arduino. I would be very happy if you could explain how I should do this.
Message 12 of 20
(833 Views)
So LabVIEW will be running on a computer that is connected to the Arduino?
Message 13 of 20
(826 Views)
Yes
Message 14 of 20
(815 Views)
@Cagri1 wrote:
Yes
 Ok, if you are using a USB cable to connect the two then you can use a virtual com port over USB.
Message 15 of 20
(784 Views)
I will receive the GPS data coming with Arduino. I will show that data on the map I created with the block diagram in LabView. How will I create the map visual offline in LabView?
Message 16 of 20
(778 Views)
I feel like you are hesitant to share information about your project yet you desire someone to guess how you have implemented things and provide a solution to your problem. The more info you give the better the forum will be able to help you.
Without knowing anything about your code, I can only guess you are using some online service to generate your map so if you want to view it offline you will need to buffer the map info locally so it can continue to be displayed when there is no internet connection.
Message 17 of 20
(767 Views)
I want to view the map offline in labview and track the location on the map. I am using labview 2024 and offline map api. How should I connect the reference entry in the Initialize map blog? I am getting a property node error. How should I use the property node? I would be glad if you could help me.
Message 18 of 20
(671 Views)
To get forum help, you need to post your code here on the forum. If you can't post your code on the forum for whatever reason, you need to hire a LabVIEW developer to work on your project.
Message 19 of 20
(654 Views)
When I say code, is it Raspberry code or LabView block diagram?
Message 20 of 20
(612 Views)
