manipulate data
Hi everyone,
I am trying to organize my data but I can't do that. I receive  2 files in a different time and I want to put it in the same line, for example, my first file has a packet with 3 columns and 2 lines and the second has 4 columns and 2 lines and I want to put my second data after the first but in the same line (As I said, I receiveit in a diferent time). In other words, besides I receive my packet in a different time I'd like to put the second data after the first but aligned.
Let's suppose my packets:
1)
1    55    32
4    65    15
2)
3    12    14     5
12  54      4     9
I want to do that:
1    55    32    3    12   14   5
4    65    15   12   54     4   9
Remember, I receive in a different time!!
Is it possible to do that?
Is there anybody that can help me?
(3,720 Views)
Hi Kito,
maybe the attachment can help you...
When you know the array sizes before you can also init a big "buffer" array and use "replace array subset" instead...
Message Edited by GerdW on 07-07-2009 10:43 PM
(3,716 Views)
HI GerdW,
I know exacly the array size before. It is 508 bytes and the second one is 255.
Could you help me how to use "big"buffers"and replace arrays subset.
Regards
Kito
(3,705 Views)
HI GerdW,
I forgot to tell you that I will receive continuously the data. So I need to include those data in the sequence of the file. For exemple:
First time
1)
1    55    32
4    65    15
2)
3    12   14   5
12   54     4   9
2nd time
1)
 5    85    92
 9    32    18
2)
 13   33   18   1
17   44     3   8
and so on....
and then the struct will be like that:
1    55    32    3    12   14   5
4    65    15   12   54     4   9
5    85    92   13   33   18   1
9    32    18   17   44     3   8
..........and so on.
Could you help me on that?
Regards
Kito
(3,693 Views)
Hi Kito,
the attachment shows how to use a "buffer" array and to (re)place incoming data in the buffer...
(3,666 Views)
Thanks very much for your help GerdW.
It really helped me.
Regards
Kito
(3,645 Views)
