‎06-19-2008 03:56 AM
‎06-19-2008 03:59 AM
‎06-19-2008
04:11 AM
- last edited on
‎04-06-2025
06:43 PM
by
Content Cleaner
Since i asume that the LV application should run independend from TestStand, i think that the data really has to be extracted from the database. The easiest way to do this is to use Database Connectivity Toolset for LV. If you don't have access to this tool (and cannot purchase it), you can either go the hard way and implement the needed functions on your own. But esp. for the database toolset, this will be very difficult.
The other possibility is to use an "interim tool" which does the database-communication for you. The data retrieved has to be accessable from LV nevertheless, so you have to get it either using files, TCP or other "multiapplication communications channels".....
hope this helps,
Norbert
‎06-19-2008 04:28 AM
Hi Mike. I dont have the report Genaration toolkit. The prefered format is Word. The program is build in LabView with a Call to Teststand that genarates the data and puts it in a database. Are there any free tools to retrieve this data in a reasonably easy way?
Thanx
‎06-19-2008 04:30 AM
Hi Norbert, what do you mean by Interim Tools?
Thanx
‎06-19-2008 04:47 AM
‎06-19-2008 04:49 AM
