make two simultaneous processes
Hello everyone, I'm starting to use Labview and I have a simple question, but I can not find solution. Attached is a file where we can see what happens.
In the example if I make the process A,  I can not begin B until the first end. How I can do both processes simultaneously?.
Thanks for your suggestions.
(3,591 Views)
Hi framirez,
in your VI everything runs parallel - but also ends very fast as there is no loop around all your code. So everything in there for "ProcessB" will be finished soon after starting the VI...
(3,585 Views)
Thank you for your answer, but if the process A is running, while in the countdown I can not run the process B, I must wait to finish the process A. What I wish is to make the process B while A is in the countdown. (If while running the process A press switch of the process B, it does not work)
Thank you for your interest.
(3,576 Views)
Hi framirez,
it's all in message #2: make a loop around "Process B"...
(3,565 Views)
Accepted by topic author framirez
Thanks, it works correctly now.
(3,558 Views)
Hi framirez,
so the solution is "Thanks, it works now" and not "make a loop"?
(3,555 Views)
