make pop up window
@mansijain1234 wrote:
I tried using subvi but due to case structure it is not happening ...
What happens if you remove the case structure then? 😮
(Seriously, of you need help with your code, attach your VIs.)
Message 21 of 22
(2,129 Views)
Can you do the same thing by right clicking on the control so that the popup window can open?
Message 22 of 22
(1,808 Views)
