make current values default
Reinitialise to default yeah. If you do as you say for "Set Current Values
to Default" however it won't work. This method can only be used on a VI that
is not running and is not in the hierarchy of a running VI.
The method I prefer is to store all the required defaults in a text file and
load/save as needed, using local variables or otherwise to shove the values
into the front panel terminals at run-time.
sarah wrote in message
news:50650000000500000030330000-993342863000@exchange.ni.com...
> All you have to do to make all your current values default values, is
> to set up an application reference to the current VI and then wire
> this to an invoke node. One of the methods is 'Set Current Values to
> Default'. I believe that you can use this s
ame methode to reinitialize
> values to the default state.
Message 11 of 11
(889 Views)
