make bode plot using Multisim connectivity toolbox
Hi
I have bulid low and high pass filter in  Multisim and I would like to make bode plot in LabVIEW to demonstarte the functionality of these filters ( an interactive session for student to let them for example finding threshold voltage using bode plot garph)
I use Multisim connectivity ver 1 to connect Multisim to LabVIEW.Would you please help me how can I work with AC Sweep function of this toolbox and is it possible to make bode plot using this function.
Many thanks
(6,021 Views)
Hi there en99,
Thanks for your post, I have had a look into this for you and have found the following information.
However, in terms of the Bode plot, this can only be done with the functions available in either the Sound and Vibration Module or, and more relevantly, the Control, Design and Simulation toolkit which are purchased separately.
More information can be found in the linked Discussion Forum that I found asking a very similar question.
https://forums.ni.com/t5/Signal-Generators/how-to-make-bode-plots-in-Labview-7-1-without-using-Contr...
Hope this helps!
Liam A.
(6,006 Views)
Hi Liam
Many thanks for your reply.I have gone through that linke before and I have worked with most of the Multisim connectivity toolbox but I dont't know how can I work with this particular function of this toolbox.AC Sweep.I would really appreciate if someone show me how to work with this function by a simple example.
(5,999 Views)
