maintaining sbrio deployments
I have an application running on a SBRIO with custom FPGA and realtime code.  The code is compiled and and set to run at startup.  The code acts as a data server to a labview client application using tcpip (no shared variables- just raw TCP-IP).  All I should need on the client application is the 2009 runtime engine and the labview client executable.  My questiuon is on maintaining the SBRIO- can the code be lost (is this unlikely) and if so I need an easy ability to redeploy the compiled application, hopefully without addint large installers.  Is there a utility for redeploying outlede of max or from the LV development environment.  Also I would like to beable to do this for the RT code patched, ie remote deploy from my office with new features.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,743 Views)
As a quick and dirty option I keep a back up of the whole content of a RT target disk...
In an example I've right in front of me it's 24Mb (zipped).
Marco
(2,731 Views)
Thanks, what is the best method of backing (ghost copy) up and then restoring this copy.
I am trying to avoide extra applications on the client PC but I could do this on a secondary maintanance PC.
Paul Falkenstein
(2,726 Views)
This should give you an idea:
RT Target System replication
NI-RIO System replication
I really recommend you to read the cRIO Developers Guide too. This guide provides an overview of recommended architectures and development practices when programming NI CompactRIO/sbRIO controllers.
Luca
(2,710 Views)
