macOS USB serial?
The problem I now have also, need to get NI-VISA uninstalled, so that the system is in condition before installing it. The code that uses serial does not open any more after installing NI-VISA.
Message 11 of 13
(760 Views)
So what exactly should I do to remove the NI_VISA from the macOS. This is super unclear, with confusing options. I just vant the macOS as it was before installing NI_VISA. SO should I really do all this manually and what exactly, I do not trust or understand these instructions.
NI-VISA 20.0.0 for Mac OS X
Required Component:
NI-VISA Runtime
Optional Components:
NI-VISA Development Support
NI-VISA Configuration
NI-VISA Server
NI MAX
NI I/O Trace
Support Packages:
NI-PAL
NI-RPC
NI System API
LabVIEW 2019 Runtime
To uninstall NI-VISA for Mac OS X, you must remove the following
files and folders from the system. To completely remove all National
Instruments software from the system, you can also remove the
support packages by following the instructions in the "Support
Packages" section below.
Required Component
NI-VISA Runtime
Before removing this component run 'launchctl remove nilxid' as root.
/Applications/National Instruments/NI-VISA
/Library/Application Support/National Instruments/NI Spy/APIs/3
/Library/Application Support/National Instruments/Errors/Chinese/VISA-errors.txt
/Library/Application Support/National Instruments/Errors/English/VISA-errors.txt
/Library/Application Support/National Instruments/Errors/French/VISA-errors.txt
/Library/Application Support/National Instruments/Errors/German/VISA-errors.txt
/Library/Application Support/National Instruments/Errors/Japanese/VISA-errors.txt
/Library/Application Support/National Instruments/Errors/Korean/VISA-errors.txt
/Library/Application Support/National Instruments/NI-VISA
/Library/Application Support/National Instruments/Legal Information/NI-VISA com.ni.NI-VISA_Runtime.LibAppSupp
/Library/Application Support/National Instruments/uixml/sysconfig/nivisa*
/Library/Application Support/National Instruments/uixml/Launchable Apps/nivisa.testpanel.plist
/Library/Application Support/National Instruments/nisysapi/nivisaExpert.ini
/Library/Application Support/National Instruments/nipal/BootDrivers/NiViPciK.rc
/Library/Preferences/NIvisa
/Library/Frameworks/VISA.framework
/Library/LaunchDaemons/nilxid.plist
/Library/Extensions/NiViPciK.kext
Optional Components
/Applications/National Instruments/NI-VISA/Examples
/Applications/National Instruments/NI-VISA/Help
/Applications/National Instruments/NI-VISA/Driver Wizard.app
/Applications/National Instruments/NI-VISA/NIvisaic.app
/Library/Application Support/National Instruments/NI-VISA/LabVIEW
/Library/Preferences/NIvisa/.LabVIEW
/Applications/National Instruments/NI-VISA/LvEnetconf.framework
/Applications/National Instruments/NI-VISA/LvIniconf.framework
/Applications/National Instruments/NI-VISA/NI-VISA Configuration.app
NI-VISA Server
/Applications/National Instruments/NI-VISA/NI-VISA Server.app
Receipt Components
Run pkgutil --forget [pkg] on the following packages for parts that are being
removed.
NI-VISA Runtime
com.ni.pkg.nivisaruntime
com.ni.NI-VISA_Runtime.LibAppSupp.pkg
com.ni.NI-VISA_Runtime.LibExt.pkg
com.ni.NI-VISA_Runtime.LibPrefs.pkg
com.ni.NI-VISA_Runtime.App.pkg
com.ni.NI-VISA_Runtime.LibLaunchd.pkg
com.ni.pkg.nivisadevelopment
com.ni.NI-VISA_DevSupp.LibPrefs.pkg
com.ni.NI-VISA_DevSupp.LibAppSupp.pkg
com.ni.pkg.nivisaconfiguration
NI-VISA Server
com.ni.pkg.nivisaserver
NI MAX
For instructions on how to remove this product, see:
/Library/Application Support/National Instruments/nimax/Uninstall.txt
NI I/O Trace
/Applications/National Instruments/NI IO Trace/Uninstall.txt
Support Packages
NI-PAL
Other hardware drivers on your system may require this component. Remove this
component at your own risk. For instructions on how to remove this product, see:
/Library/Application Support/National Instruments/nipal/Uninstall.txt
NI-RPC
Other applications on your system may require this component. Remove this
/Library/Application Support/National Instruments/nirpc/Uninstall.txt
NI System API
/Library/Application Support/National Instruments/nisysapi/Uninstall.txt
Other applications on your system may require this components. Remove this
component at your own risk. To remove this component, remove the following
framework bundle.
/Library/Frameworks/LabVIEW 19.0 Runtime.framework
To remove the installer receipt for this component run:
pkgutil --forget com.ni.LabVIEWRuntime190
Message 12 of 13
(754 Views)
The only solution to this problem is not use Big Sur and now I have the problem how to remove NI-VISA from Big Sur.
Message 13 of 13
(712 Views)
