macOS Big Sur: Labview crashes on launch
David,
See Craig's answer in this same thread above.
Short story: you need to change com.mycompany.myapp to your app's "internal name" (bundle identifier), which is specified in your LabVIEW app's build specifications (in the LabVIEW Project).
Message 21 of 40
(3,620 Views)
Yes, I used the Internal Name.
Message 22 of 40
(3,618 Views)
Process:               ClockLab Analysis [18350]
Path:                  /Users/USER/Desktop/*/ClockLab Analysis.app/Contents/MacOS/ClockLab Analysis
Identifier:            ClockLabAnalysis
Version:               1.0.0.155 (1.0.0)
Build Info:            lvapp-300001~0
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           ClockLab Analysis [18350]
User ID:               504
Date/Time:             2020-12-02 12:38:58.108 -0800
OS Version:            macOS 11.0.1 (20B50)
Report Version:        12
Anonymous UUID:        2BB81ECB-2666-BF47-2A21-037AEAB41610
Time Awake Since Boot: 170000 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_INSTRUCTION (SIGILL)
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Signal:    Illegal instruction: 4
Termination Reason:    Namespace SIGNAL, Code 0x4
Terminating Process:   exc handler [18350]
Application Specific Information:
Attempt to pop an empty graphics context stack.
Internal name is ClockLabAnalysis
Commands used:
defaults write com.actimetrics.ClockLabAnalysis NSGraphicsContextAllowOverRestore -bool YES
defaults write com.actimetrics.ClockLabAnalysis NSViewAllowsRootLayerBacking -bool NO
Errors:
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0   com.apple.AppKit               0x00007fff22c4dbc1 +[NSGraphicsContext _popGraphicsContext] + 203
1   com.apple.AppKit               0x00007fff22c4dae1 +[NSGraphicsContext restoreGraphicsState] + 22
2   com.ni.labviewRuntime          0x00000001094c9ab1 WSetClipRgn + 417
3   com.ni.labviewRuntime          0x000000010943a743 ISetGPort + 627
4   com.ni.labviewRuntime          0x00000001094cda3a WSetPort(Wind_t**) + 138
5   com.ni.labviewRuntime          0x00000001094cc1b7 WSetBounds(Wind_t**, Rect, int, int) + 871
6   com.ni.labviewRuntime          0x00000001094cb5f9 WSize + 169
7   com.ni.labviewRuntime          0x00000001088e01e8 HeapUpdateWindowStyleCore(ObjectHeap*, ExecutionStateChange, Wind_t**, int) + 3288
8   com.ni.labviewRuntime          0x00000001088dcec0 DrawLocalVIState::DrawSetVIActive(VirtualInstrument*)
Message 23 of 40
(3,613 Views)
Can you post the error log of the crash? This will contain the bundle name, to confirm the exact command that should be executed.
Message 24 of 40
(3,614 Views)
If the internal name is ClockLabAnalysis I think you need to use the following commands:
defaults write "ClockLabAnalysis" NSGraphicsContextAllowOverRestore -bool YES
defaults write "ClockLabAnalysis" NSViewAllowsRootLayerBacking -bool NO
The quotes are optional, since no spaces, but I've added them so that others who copy+paste this might need them for their own application.
Message 25 of 40
(3,607 Views)
It worked! Thanks so much.
David
Message 26 of 40
(3,580 Views)
That's great!  However, it means you are using just "ClockLabAnalysis" as your Internal Name, and this violates the conventions of a bundle identifier, which is always a tuple in reverse DNS notation.
You should probably use something like "com.actimetrics.ClockLabAnalysis" for both the Internal Name in the build spec and the argument to the two 'defaults write' commands, just to be standards-compliant.
Message 27 of 40
(3,548 Views)
Thanks for that info. I wasn't really clear to me (and maybe others) this was a standard when filling out the build specification in LabVIEW.
Message 28 of 40
(3,541 Views)
Message 29 of 40
(3,503 Views)
I solved the problem using two following commands:
defaults write "com.ni.labview" NSGraphicsContextAllowOverRestore -bool YES
defaults write "com.ni.labview" NSViewAllowsRootLayerBacking -bool NO
https://support.vipm.io/hc/en-us/articles/360052653212-VIPM-2020-1-Crashing-on-macOS-11-Big-Sur-
Message 30 of 40
(3,443 Views)
