mac G4 OSX DAQ problems
I am attempting to run LabVIEW 7.0 on a mac G4 with OSX (10.3). I downloaded the newest NI-DAQ driver DAQmx 1.4 and installed it. I have a PCI-6025E board installed in the machine.
NI-DAQmx Base Config recognizes the PCI board and allows me to configure it.
If I attempt to run in the Classic environment,the NI-DAQ Configuration Utility does not recognize the board. I cannot therefore configure and use channels.
Thomas D. Schaefer
Wells Manufacturing Corp
(2,583 Views)
Why are you trying to run under the classic environment? LabVIEW 7 is an OS X app, and I believe the same is true for the new DAQmx drivers. It does not surprise me that you would have problems communicating with hardware between OS X and the classic environment as hardware is abstracted from the "TrueBlueEnvironment". You would need a classic version of the DAQmx drivers. Do you have any trouble accessing your hardware from the native environment?
Chris
(2,570 Views)
