ma_Check block size
I inherited LV6.1 code that I'm trying to bring into LV11. LV11 is complaining that it can't find two VIs:
ma_Check Block Size.vi
ma_Spectrum Peak Hold.vi
There are two VIs with similar names already on my LV11 machine:
ma_Check Block Size no State.vi
ma_Spectrum Peak Hold no State.vi
Can I just copy the two missing VIs from my LV6.1 library into my local directory on my LV11 machine? Am I running any risks in doing so? Thanks.
(2,359 Views)
Hi efarr,
Based on the How to Upgrade or Revert a VI to a Different Version of LabVIEW tutorial, you should be able to open LabVIEW 6.1 VIs in LabVIEW 2011. As a result, you should be fine copying the two missing VIs to your local directory and telling LabVIEW to use these VIs.
Tunde S.
(2,340 Views)
