lvrt.out
Hi all,
I am using a Crio module and had an issue with the internal memory being full.
I found a file taking 150Mb under the following directory:
ftp://169.254.125.17/tmp/lvrt.out_11.0__log.txt
it is growing at an very fast rate since the first logged date is 3 days ago.
And apart from a few lines all the logged warnings are:
10/11/11 12:53:15.247 PM
DWarnInternal 0x0: If write was busy before, it can not be busy now when we can
write
source/server/protocolcomm.cpp(1258) : DWarnInternal: If write was busy before,
it can not be busy now when we can write
This message is sometime logged every 2miliseconds but the quickest loop we
have is running at a 15msec.
My first question is, can I delete this file or part of it?
And also do you know the reason why this file is growing so fast?
Kind regards
florent
(2,994 Views)
Hello Florent,
The problem you are having is something we have seen before. It lies at a very low level and such the issue is being worked on by our R&D department. I have added your specific problem to their records so I will receive notifications on their progress as they come to a solution though I cannot say exactly when this will be.
For the mean time my best recommendation is that you add some code to your cRio that periodically deletes the error file.
I apologies for the inconvenience you are experiencing.
Kind regards
Jack. W
(2,926 Views)
Hello again Florent,
Forgive me, I forgot to say how best to delete the file as you asked.
To do this as I suggest in your code there is a VI that can be found in the Functions palette : File IO palette » Adv File Funcs palette » Delete VI
Hope this helps
Jack. W
(2,921 Views)
even under consideration that this thread is 9 months old, I would like ask if there are updates or solutions to this bug since I have the same problem. I already posted it here
http://forums.ni.com/t5/Real-Time-Measurement-and/Running-out-of-disk-space-tmp-folder-full-on-cRIO-...
but now it gets even worse. The lvlog.txt and lvrt_out.txt files grow up to several hundred MB and fill the whole disk within some days. So basically I have to delete this files every couple of days to work with my cRIO system.
The only message in the files is
DWarnInternal 0x0: If write was busy before, it can not be busy now when we can write
source/server/protocolcomm.cpp(1258) : DWarnInternal: If write was busy before, it can not be busy now when we can write
Thanks for your help.
Best regards
Andy
(2,873 Views)
