I had an application built using LabView 5 on Win98 system and it was running perfectly, I decided to upgrade the system to Windows XP,then, i used Labview Run-Time Engine 5.1.1, i was surprized when the application ran perfectly also (I know that 5.1.1 works only till Win2000!!!), BUT, after 10 to 15 minutes from idle process, i get an error from WinXP saying that there was a problem in my exe file because of (lvrt.dll), when i restart the application it runs OK.
I'd like to add more info:
- The application is using Traditional DAQ Card.
- The application includes ActiveX & Networking.
- I don't have the source code to modify anything.
Any one has a clue what to do to avoid this error????
