lvm writing
Hi all
I'm trying to run the Vi in attachment but after few seconds it turn back this error:
Possible reason(s):
Attempted to read samples that are no longer available. The requested sample was previously available, but has since been overwritten.
Increasing the buffer size, reading the data more frequently, or specifying a fixed number of samples to read instead of reading all available samples might correct the problem.
Property: RelativeTo
Corresponding Value: Current Read Position
Property: Offset
Corresponding Value: 0
Task Name: _unnamedTask<7>
I need to run the Vi with a 1 second rate in write the data on a lvm file ( always 1 samples per second)
Anyone can help me?
Thank you
(2,785 Views)
anyone can help me?
The error number is:
Error: 200279 instance 1:1
(2,663 Views)
Accepted by topic author Teo_CF
The DAQ assistant must be out of the loop
(2,613 Views)
