lvlib Add Options
I have a bunch of VI under a particular lvlib.  I thought I would organize the VIs a little, so I created multiple lvlibs under the original lvlib and organized my VIs according.  Then, I realized that under the add option, there are file, folder (snapshot), and hyperlink.  I am most interested in the folder (snapshot).  What does snapshot means?  What you explain each options a little?
Is it true that I probalby should create one lvlib and multiple folder (snapshot) under the lvlib to organize my VIs, instead of create multiple lvlibs under one lvlib?  Thanks!
Yik
Message 1 of 9
(5,342 Views)
yik
yup yik,
jyang72211 wrote:
I have a bunch of Vs
Iinterested in the folder (snapshot).  What does snapshot means?  What you explain each options a little?
Yik
No- I cannot explain each snap-shot too you, and really- why would you want this!!!   your posts show that you CAN use the LV:help"
You CAN ask a better question than this one.... please do!  (Just a Grumpy old man)
"Should be" isn't "Is" -Jay
Message 2 of 9
(5,332 Views)
A snapshot 'add' option is used to easily import all the files (and sub-folders) into a LabVIEW library or project. The term 'snapshot' means that only the files currently in the folder will be added.
Ton
My LabVIEW Ideas
Message 3 of 9
(5,324 Views)
Grumpy - I guess it was a bad questions.  What I should have asked is what is the preferred way of organizing files in a lvib?  Can anyone shed some lights on this?
TC - thanks for explaining this.  If you add a fold snapshot (currently have 5 VIs in it) to the lvlib and later add 2 more VIs into the folder, the snap shot folder in the lvlib will still appear to contain the 5 VIs from the moment you created the lvib, and the 2 new files will not show up there, since the snap shot doesn't update the folder?
Yik
Message 4 of 9
(5,308 Views)
Hi Jeff,
On a side note, I tried to download the free code capture tool.  When I tried to open the vi for installation, the vi try to find a component, but it is unable to do so.  Becasue of this, I can't install the tool.  Can you help?
Yik
Message 5 of 9
(5,307 Views)
Sorry about that-  I was out of line Please accept my appologies
Message 6 of 9
(5,295 Views)
Jeff,
Not a problem.
Yik
Message 7 of 9
(5,281 Views)
jyang72211 wrote:
Hi Jeff,
Yik
jyang,
could you sent a screenshot of the search for the missing component?
Have you extracted the all contents of the zip-file to a folder?
What LabVIEW version on what platform are you on?
Ton (CCT-developer)
My LabVIEW Ideas
Message 8 of 9
(5,257 Views)
You were right.  I just didn't unzip the file.  Thanks!
Yik
Message 9 of 9
(5,213 Views)
