lvanlys.dll loads from diff LV folder paths
LabVIEW 2001.SP1, Windows7/64, FPGA Module, custom FPGA VIs and bitfile created.
How do I stop the cross loading message?  I suspect one of the FPGA functions is loading first and establishing a VI Search path I do not want.
Program loads lvanlys.dll from two location in LabVIEW folder path.  They are actually located (first & second in the image) in:
C:\Program Files (x86)\National Instruments\LabVIEW 2011\
    vi.lib\LabVIEW Targets\FPGA\RIO\R Series\78XXR\783XR\Calibration\78XXR Calibration DLL\data\lvanlys.dll
    resource\lvanlys.dll
When the project VIs load, I keep getting a warning about expected versus actual loaded paths for the lvanlys.dll file for standard <vi.lib> analysis VIs
Complicating matters are VIs in the project containing direct DLL calls to lvanlys.dll (reasoning unknown for inherited code) and show the path as lvanlys.* but when viewing DLL nodes of random LV analysis VIs (mean, lin fit, etc) they all show their paths as the one in the resource path shown above.
I know this problem is related to 'the first dll instance to load' behavior since opening a vi.lib analysis VI BEFORE loading the project causes the same problem BUT for the other functions (the ones originally OK).
Any advice on how to resolve this?
Thanks, Dave
(3,185 Views)
My first step would be to fix the direct calls to the analysis library. I can think of a couple reasons why someone might do that in old code, but none of the reasons are valid now. For instance, there is a build option that tells LV to not remove unused routines from libraries. There was a bug in the early OOP stuff that you had to include all members of a library -- and the analysis library is VERY large.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,163 Views)
