lvalmark.sys and nitiork.dll caused Blue Screen sometime
Hi Everyone
I am a Labview programmer, debugging Labview 2011 programmes on a WinXP 32bit system.
I recently ecountered this weird situation, that is, Labview system component causes computer crash when I was debugging the code, mostly when I was changing stuff in Block Panel.
By analysing the dump file of windows, I got the following informations.
MODULE_NAME: nitiork
FAULTING_MODULE: 804d7000 nt
DEBUG_FLR_IMAGE_TIMESTAMP: 4d8a0ff6
READ_ADDRESS: b10300d4
CURRENT_IRQL: 1b
FAULTING_IP:
nitiork+6e6b
ac93ee6b ?? ???
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: DRIVER_FAULT
BUGCHECK_STR: 0xD1
LAST_CONTROL_TRANSFER: from 00000000 to 805446f0
STACK_TEXT:
ba4d3b1c 00000000 b10300d4 0000001b 00000000 nt+0x6d6f0
STACK_COMMAND: .bugcheck ; kb
FOLLOWUP_IP:
nitiork+6e6b
ac93ee6b ?? ???
SYMBOL_NAME: nitiork+6e6b
FOLLOWUP_NAME: MachineOwner
IMAGE_NAME: nitiork.dll
I am realy grateful if someone can tell me what to do to avoid crashes happening again, because bluescreen crash on a lab measurement computer is really annoying!
(2,433 Views)
HI,
i did some research and found some similar cases. The solution sounds simple and I hope it works for you. Just install the latest DAQmx Driver and reboot your Computer.
NI-DAQmx 9.9
http://www.ni.com/download/ni-daqmx-9.9/4707/en/
(2,400 Views)
To add to Gregors reply: You are aware of the fact, that Microsoft stopped any support on Windows XP?
Therefore, i recommend you to update your Windows as no vendor will support their products on Windows XP anymore as well (that means: if you find bug, it will not be addressed if the product running on a newer OS version doesn't show the bug).
Norbert
Norbert
Expert: Geometry
(2,395 Views)
