lvalarms.dll
Hi all,
where is the difference between the lvalarms.dll in the system folder off the RT target (PXI 8106) and the lvalarms.dll in the build folder? The one on the rt target has a size of 156 KB and version 1.0.0.49152, the one in the build folder has a size of 181 KB and version 8.5.1.1.
Which one do i need to build an application with "normal" timed loops and "external" triggered timed loops which use the "create timing source vi", both are in one vi? The vi with these loops run well in the development enviroment, but not in the application.
Thanks in advance
EgonS
(2,695 Views)
Hey,
The different size/version might be from different installations or versions of your LV Version on the target and form the one of your host.
Usually, you should not care about lvalarms.dll when building an application for an rt target.
Can you explain a bit more in detail what exaclty is not working on the target? Any errors?
Christian
(2,677 Views)
