lv71/labview: realloc(): invalid next size:
Linux Weenies;
I've had good luck running LV7.1 on Suse 10.1 and 10.3 (x86_64).  I have installed the box version from Novell of Suse 10.3 and now get the following errors:
*** glibc detected *** /usr/local/lv71/labview: realloc(): invalid next size: 0x223b1bf0 ***
(no debugging symbols found)
======= Backtrace: =========
/usr/local/lv71/lib/libc.so.6[0xf7bea4b6]
/usr/local/lv71/lib/libc.so.6[0xf7bed7ed]
/usr/local/lv71/lib/libc.so.6(realloc+0x10a)[0xf7bee1aa]
/usr/local/lv71/labview[0x822752d]
/usr/local/lv71/labview(DSSetHandleSize+0x69)[0x82262c9]
/usr/local/lv71/labview(FAppendName+0x60)[0x823c970]
/usr/local/lv71/labview(_Z9FListDir2PP6Path_tPP5CPStrPP10FMFileTypei+0x24f)[0x81d972f]
/usr/local/lv71/labview[0x86a5996]
/usr/local/lv71/labview[0x86a5a8e]
BTW:  I have tried placing earlier versions of glibc within /usr/ocal/lv71/lib/, it then can't find all the older x libraries etcetera.
   ...Dan
(4,126 Views)
Hi Dan,
What versions of the kernel and NI-KAL do you have?  Also, what versions of glibc have you tried to use?
Jennifer R.
(4,093 Views)
The kernel is:
Linux version 2.6.22.5-31-default (geeko@buildhost) (gcc version 4.2.1 (SUSE Linux)) #1 SMP 2007/09/21 22:29:00 UTC
glibc is:
2.6.1-18 (and I've tried 2.2, 2.3, 2.4, 2.5)
NI-KAL?  How do I find out?  Just for giggles, I looked it up and downloaded it, tried to make it but it complained about my 64 bit system.  The thing is, I have had it working on my 64 bit system before the OS renewal (clean hard drive).
   ...Dan
(4,089 Views)
For what it's worth, running gdb on LabView shows an infinite loop at:
#0  0xffffe405 in __kernel_vsyscall ()
#1  0xf7c8f8d6 in __lxstat () from /lib/libc.so.6
#2  0x081d9797 in FListDir2 ()
#3  0x086a5996 in ?? ()
#4  0x086a5a8e in ?? ()
-- snip --
#4248 0x086a5a8e in ?? ()
#4249 0x086a5948 in ?? ()
#4250 0x086d6052 in OMIVIClassMgr::Init ()
#4251 0x086c0264 in ObjManagers::RegisterObjClassManager ()
#4252 0x086bfe78 in RegisterObjClassManager ()
#4253 0x086bff99 in InitObjMgr ()
#4254 0x08597a42 in InitApp ()
#4255 0x085b2146 in ?? ()
#4256 0x085b51d7 in ?? ()
#4257 0x08282835 in ?? ()
#4258 0x08282cca in WSendEvent ()
#4259 0x0822c9f4 in InitializeApp ()
#4260 0x08230a8e in ?? ()
#4261 0x08230b03 in main ()
Hopefully, someone familiar with the internals can help figure this out.
   ...Dan
(4,072 Views)
Never mind, I found the solution.  The problem appears to be with ext3 filesystems, the solution is in this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=83794&query.id=503762#M83794
namely:
tune2fs -O "^dir_index" /dev/hda1
(4,071 Views)
Hi Dan,
NI-KAL is a low-layer driver between the Linux kernel and National Instruments software.  You can find information on the various versions under What is “an appropriate version of NI-KAL”?  However, it sounds like the version you have currently is fine.
I'm glad to hear you've found a solution.  Thanks for sharing the information.
Jennifer R.
(4,054 Views)
