<absolute time>
If i place a Timed loop with "1KHz <absolute time>" timing source and "Process missed periods" mode, with any Period, i get the loop running untimed, at superfast speed... Like it is trying to process all missed periods since timestamp zero in 1904!! No way to reset the timing source? Is absolute time simply incompatible with Process missed periods?
Also, it seems impossible to create an absolute timing source with "Create timing source"
(3,248 Views)
can you post your code
David
www.controlsoftwaresolutions.com
(3,222 Views)
Just place a timed loop, select "1KHz <absolute time>" and uncheck "Discard missed periods".
Labview 9 needed
(3,210 Views)
