*.lsb in MSVC++6
I am trying to generate a CIN for the following example C code (mult.c)
* CIN source file
#include "extcode.h"
CIN MgErr CINRun(float32 *A, float32 *B, float32 *AB);
CIN MgErr CINRun(float32 *A, float32 *B, float32 *AB) {
*AB = *A * *B;
return noErr;
C:\Program Files\National Instruments\LabVIEW 6\cintools\
in the Additional include directories
for code generation selected multithreaded DLL and 1 byte
and on custom build typed the following for commands
"C:\Program Files\National Instruments\LabVIEW 6\cintools\lvsbutil" "$(TargetName)" -d "$(WkspDir)\$(outDir)" (all in one line)
and in the output typed
$(OutDir)$(TargetName).lsb
I also made sure that I have settings as All configuration
when i build the dll
the status is
mult.dll error(s)0 ,warnings 0
but there is no mult.lsb file created.
i have followed the steps given in the manual using External Code.july edition .
i am using MSVC++ version6 and my Labview version is 6i.
pls help,
regards
sithara
(2,629 Views)
sithara,
I also follwed the directions on page 3-14 of the Using External Code in LabVIEW manual except not including the Win32 directory instructions since this directory has been removed in LabVIEW 6.0.0 and above. I used the same set of instructions that you did as well. Are you building for the right configuration? Did you set the settings for debug, but are building under release? Also, make sure to include the four files (cin.obj, labview.lib, lvsb.lib, and lvsbmain.def). Without these files, the .lsb file will be created, but it will not work. My guess is that you are building in the wrong configuration because you should see a message that the custom build went successfully and you do not show that message in your post.
Randy Hoskin
Applications Engine
er
national Instruments
http://www.ni.com/ask
(2,629 Views)
