03-11-2008 11:14 AM
06-17-2008 02:14 AM
06-17-2008 03:01 AM
Hi, I had problems with my PC. First I had to format it because on other computers the applicationd was not so slow. Second I was using LV 8.5 and I figured out that LV 8.5 is really heavy for my application (I use plenty of indicators) had 45% cpu usage on a Intel core duo (2cpus). Then I switched back to LV8.2 (no problem with LV 8.2) and my application really improved a lot using FTDI compared to rs232.
Anyway I had to purge the buffer outside the sequence of the example FTDI provide. I purge the buffer in sections when I do not use the device.
08-02-2011 08:48 PM
hi, im using ft245 too, i took the tfdi's example, but i cant to do communication very well, could you post you example
thanks
JC UASLP, MX
