low pass filter and peak detection
Hello everyone,
my code generates two different waveforms and im using NI 6009, however i am uncertain on how and very exactly to implement low pass filter in order to acquire smoother plots, in addition, i want to be able to use peak detection script in labview.
Thank you
(3,402 Views)
The most simple way would be to use the in-built functions in LV.
These should do the job 🙂
(3,401 Views)
Hi Tom,
what are the recommended values for fs, fh and fl.
Cheers,
Yazan
(3,374 Views)
all VIs have default values for their terminals, that doesn't mean they are recommendend in general (and i don't know either).
i think you will have to play with it a little.
as a starting point, i added the snippet .png which you can save and drag+drop onto a block diagram.
regards
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,366 Views)
Ive added the low pass filter on my block diagram but i havent been able to achieve that smooth curve. I am using a NI USB-6009 for my project and my frequency is 2 kHz.the top is the main output plot, and the other two are after i placed the low filter pass you can see from my block diagram i attached. Thanks in advance.
(3,347 Views)
