loop size changing
I'm new in labview. Does anyone know how can I increase the size of the loop?When I double-click on the loop to enlarge it as like we do with other windows, I don't see any change on the loop?and also how can I move the icons in the block-diagram window?
Labview version:7.1
windows XP
Daqmx 8.9
thanks
Message 1 of 10
(6,129 Views)
Hi vahi,
don't you think taking the FREE online beginner courses would do you good?
Basic stuff like selecting BD elements, moving selected elements and also changing the size of selected elements should be learned at first…
Message 2 of 10
(6,114 Views)
When did the auto tool selection become part of LabVIEW? Version 7.1 is absolutely ancient but not do old that you wouldn't have the Tools palette and be able at least manually select the correct one. Double clicking does nothing in other Windows either so that statement makes no sense.
Message 3 of 10
(6,102 Views)
Things like "Crtl+M" toggles between Edit Mode and Run mode, behavior of read only vi files, Crtl+Drag makes space on the sub diagram, and tool section are covered in the getting started exercizes.
"Should be" isn't "Is" -Jay
Message 4 of 10
(6,092 Views)
When I watch the tutorial video, the first thing which it says is "View/Tools Palette"...But I don't have "View" tab in LV7.1....Furthermore, when I search "Tool Palette"...No result!
Message 5 of 10
(6,074 Views)
Shift+Right-click worked even in 7.1  There should be a getting started with LabVIEW guide at:
C:\Program Files (x86)\National Instruments\LabVIEW 7.1\manuals\LV_Getting_Started.pdf  and one called LV_Quick_Referance.pdf.  Print that last one and tape it to your wall.
Message 6 of 10
(6,066 Views)
Thank you so much, I really appreciate it.
It was so helpful
Message 7 of 10
(6,063 Views)
thinking.......
no "View" Menu or "No Menu Bar"
Ctrl+I opens the vi property dialog.  Check "Protection" and unlock the vi.  Window Appearance select customize and check the Window has menu bar box.  Niether is likely to be covered in the GSG.
Message 8 of 10
(6,056 Views)
If you take any tutorial made recently I'm guessing you are going to find several functions that don't exist in 7.1.  Don't get me wrong the basics are the same, but you might get hung up on trying to find some equivalant function in 7.1 that has been made native in last 10+ years.  In any case here is some tutorials you could try.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
If you are just learning I'd reocommend getting the student version free for 6 months here.  I think the full student version with no time limit is only $20 from studica anyway.
Message 9 of 10
(5,970 Views)
I would guess. (8-Ball guessing is somewhat reliable) the OP was stuffed in a cube and told "Anyone can program in LabVIEW"
Message 10 of 10
(5,944 Views)
