loop address bits multiplexer
Hi!
I have 16 multiplexers (ADG 406) with a 5 bit adress for the gates. However the first bit is the enable bit, and I have it always
"on", so my question is for the remaining 4 bit in the adress.
Q: Is it possible to create a cycle or loop so that the 4 bit adress changes for each multiplexer?
Example: Multiplexer 1 has the adress 0000 for gate 1 in the first loop, then in the secind loop I want
it to have the adresse 0001, for instance!
Is this feasible?
Any help or link to similar questions would be very apreciated.
Cheers.
(3,308 Views)
Accepted by topic author Rsilva
Hi rsilva,
use something like this:
Set the indicator to binary display and you will see the individual bits...
Edited:
You could replace the ADD by an OR to get the same result in a more (boolean) logical way Smiley Wink
Message Edited by GerdW on 10-21-2009 03:37 PM
(3,297 Views)
Thanks GerdW!
I believe it is what I need!
Cheers!
(3,260 Views)
