logic gate inputs
Hi all
Does any one know if there is any logic functions that have more than two inputs?
Other than wiring extra inputs yourself by compounding gates!
Can't see any in the functions.
TonyC
Message 1 of 10
(5,234 Views)
yes you can use the "compound arithmetic" function in the numeric palette and set it to and or or. It is resizable
Cheers
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
Message 2 of 10
(5,226 Views)
Use the Compound Arithmetic function. You can right click and change modes to AND, OR, XOR. You can right click on any input or the output and select Invert.
Message 3 of 10
(5,220 Views)
Thanks to you both for the tip.
Yes this should just do the job....
TonyC
Message 4 of 10
(5,212 Views)
If you want some complex logic that you will use multiple times, you can also make you own subVIs.
Lynn
Message 5 of 10
(5,207 Views)
Lynn
Another neat thing about boolean algebra is, if you replace every "and" with a multiply, and every "or" with an addtion, and do the appropiate things with negation, you can evaluate the expression using regular numerical algebra.
Example:
~AB + A~B + AB + ~A~B should be TRUE (you can verify this using the distributive property)
Now we apply normal math to it:
For A and B  both TRUE (TRUE = 1)
=~1*1 + 1*~1 + 1*1 + ~1*~1
=0*1 + 1*0 + 1*1 + 0*0
=1
You can verify this works with any combination of A or B.
Another example:
take the expression A+B+C+D, with A=B=C=D=TRUE
Evaluating the expression gives you 1+1+1+1 = 4, which is equivalent to TRUE
You may be thinking, hmm, 4 is not TRUE or FALSE, but remember, in a lot of programming languages, 0 is FALSE, and anything else is TRUE.
Message 6 of 10
(5,196 Views)
Correct, that is why it is in the arithmetic palette and not in the boolean one.
Cheers
Doc-Doc
Message 7 of 10
(5,187 Views)
The compound function is in both Numeric and Boolean palettes since at least LV 6.
Lynn
Message 8 of 10
(5,181 Views)
Same in v7.1
Knowing that boolean arithmetic follows numeric arithmetic makes filling out truth tables a breeze.
Message Edited by agill on 07-12-2006 10:39 AM
Message 9 of 10
(5,174 Views)
old habits... sometimes close your eyes!
Thanks. Cheers
Doc-Doc
Message 10 of 10
(5,167 Views)
